Home > In Car Electronics > reversing cam
jk3528
reversing cam
so i have a number plate light cam but which is the best way to route the the wires to the front?
Post #614372 Sat Jun 05 2021 7:16pm
well, the problem with number plate cam's, is getting the cable from the light to the top of the tail gate.
The factoory wires appear bonded under the glass.
For this reason I fitted a ball cam in the top spoiler.
And to answer your first question, I like to go behind the roof lining, and down the passenger side
Post #614377 Sat Jun 05 2021 10:29pm
Pufftmw
As Andy says, not that easy to get wire out of the split tailgate. Mine is hidden under trim as much as possible then black duck tape where it is exposed does the trick and is not visible. Then, again as Andy says, in the headlining through to the front passenger A pillar.
Post #614381 Sun Jun 06 2021 6:47am
jk3528
Thanks looks like fun
Post #614383 Sun Jun 06 2021 8:04am
What year is your car and what you connecting it to
Post #614388 Sun Jun 06 2021 9:59am
jk3528
It’s a 2006 hopefully into the screen as I think it’s the same one as my D3 but just got to work out how to get at it?
Post #614430 Mon Jun 07 2021 10:38am
Oh do the RR mod ?
Either side of the radio are plastic (or wood panels). Get behind these at the bottom and pull them towards you.
Once that is loose the plastic surround should come out easily, including the bit below the display.
Should the air vents need to come out , then you need to remove the trim to the side of your legs. It pulls towards you and has 3 clips
Post #614435 Mon Jun 07 2021 11:35am
jk3528
Ok so do I need an adapter as the lead from the cam is not going in the back of the screen
Post #614488 Tue Jun 08 2021 9:50am
You need something like this a RCA to Fakra adapter cable, plenty on Amazon.
Post #614491 Tue Jun 08 2021 10:34am
yeap.
Then you plug it into the brown one.
Don't forget you also need to
1) program the CCF to say rear cam is fitted.
2) cut yellow wire inside it, to say its a full fat RR
Post #614492 Tue Jun 08 2021 10:43am
jk3528
Ordered is it the yellow wire in the plug that’s in the back ?
Do I need to power the cam off the reverse light?
Post #614500 Tue Jun 08 2021 12:47pm
It’s best to power the cam off the rear power socket or the Ariel amp blue wire in the rear roof side.
That way the cam still works when manurering forward, until you get above 10mph
Post #614513 Tue Jun 08 2021 2:58pm
See wire cutting inside here
https://www.disco3.co.uk/forum/hifi-teleph...74474.html
Post #614515 Tue Jun 08 2021 3:02pm
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
If the Brown connector is for the reverse camera
What are the other two for ? Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Sadly gone - 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #614516 Tue Jun 08 2021 3:02pm
Green TV
White wireless off-roading activity camera
Post #614517 Tue Jun 08 2021 3:04pm
