![]() | Home > In Car Electronics > phone wiring |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
No the wiring won’t be there.
jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 75 ![]() ![]() |
It’s says it’s an HSE has Harmon carmon sound sat nav under passenger seat and an amp under the drivers seat |
So if I fit a d4 Bluetooth unit where and what most wire do I need to connect it too |
You buy a most cable with 3 connectors on it.
So the head unit or the amp under the seat if I mount it under the seat could I pick up the power from the amp too or would it interfere with the signals
yes you could connect to the most at the amp.
Thanks |
So turns out not all D4 units have the same fibre optical socket and I have got one that hasn’t |
you have one with no fibre socket at all ?
So just to confirm pos red wire on pin 31
I don't know off hand.
Well plugged in but car still thinks it’s got no phone connected |
Have you changed the CCF file to say it has a phone fitted ? |
I think so |
