Home > Maintenance & Modifications > Land Rover Logo & No Sound from Radio
B9BS X
Hi guys
My screen displays the Land Rover sign staying on permanently and have lost all sound from radio. I have replaced battery thinking it was a power drain and battery was very old so required changing but my fault is still there.
After some research after reading a few old threads from here its recommended best to next check my bluetooth module as the fibre optics could be the cause of the fault.
Can someone direct me in the direction were the bluetooth module is located?
Thanks in advance Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #613977 Tue May 25 2021 7:12am
It’s in the boot on right side.
You probably need an optical bypass cable
Post #613978 Tue May 25 2021 8:33am
Kot
And watch the video
Post #613979 Tue May 25 2021 8:54am
B9BS X
Sorry guys forgot to mention its a L320.
There is a little opening on the drivers side in the boot were the dvd changer sits but cant see any other modules, im guessing it will be behind the trim if i take it apart? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #613980 Tue May 25 2021 9:23am
yeah, trim panel removal required.
Flop the rear seat down
https://www.ebay.co.uk/itm/Land-Rover-Disc...0ea20e36c3
Post #613983 Tue May 25 2021 10:34am
B9BS X
Thank Andy Thumbs Up
Any advice on taking the trim off? Does it just pull off or any hidden screws/bolts i need to take off first? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #613984 Tue May 25 2021 10:50am
remove the chrome luggage tie downs with an allen key.
Remove the small trim under the tie downs.
Then just a case of pulling teh side panel.
Pull the boot seal away from the trim if you need a way in.
Pull trim away
Disconnect boot light
I think you can get away without removing completly by the seat. or maybe it will make it easier.
If you think you will be in there again, don't tighten the chrome luggage tie downs
Post #613985 Tue May 25 2021 10:57am
B9BS X
Cheers again Smile RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #613988 Tue May 25 2021 11:29am
