![]() | Home > Technical > MY12 touch screen no "Extra features" option |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
I do have a dual view and the top left button say's setup, are you sure you don't have a dual view screen fitted to a vehicle that never had dual view factory fitted? I thought the setup button on a standard view screen was located buy the rotary mode switch to the right of the clock, which is where my dual view button is, hence why setup is on the screen instead.
sjm Member Since: 10 May 2021 Location: wales Posts: 5 ![]() ![]() ![]() |
Hi Col,
Not sure why you don't have extra features button as that is where the 4x4 info is located on mine along with the surround camera system on mine. Don't recall seeing anything in the ccf files to re-configure the screen but to be fair have never looked, perhaps it needs some sort of software update.
Can your nanocom pull the VIN from the screen? I suspect if it can, it won’t match your car and will be a donor part. I did have the same problem with one of my screens, and I even checked the 4x4 setting was switched on in the CCF but the only way to fix it was to replace the unit. 2019 5.0 SC SVA (Current)
Measure the diagonal distance of the screen only and tell us what it is. A DV screen is smaller than a standard screen and I think only half of it would work in a standard car. 2019 5.0 SC SVA (Current)
Hi Brit Plumber, thanks for the reply.
