![]() | Home > General (L494) > How to turn off keyless entry |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595 ![]() ![]() |
Hi , Can anyone help me on how to do this please ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
This is for D4 and L320, not sure if same for L494 but worth a try I guess.
Tried this several times and dont work ![]() |
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 ![]() ![]() |
A quick Google, and......
Does not work as per post above which is the same thing but thanks anyway |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
it does work..you need to follow the instructions to the letter and you might need to try a few times and try with the ignition on,
Okay , thanks. I will try again today |
chrisjsw Member Since: 10 Jul 2018 Location: Buckinghamshire Posts: 71 ![]() ![]() |
It does work......honest, you've got to follow the instructions to the letter and the drivers door HAS to be open 2015 Range Rover Sport L494 HSE Dynamic
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 ![]() ![]() ![]() |
Hi I have a MY13 L320 and mine would not disable the keyless entry, also it would not allow me to program new keys with the GAP tool, but after talking to Patrick at GAP, he sent across a file to flash the key module with and also a special procedure for programming new keys, which worked a treat but after flashing the module I can now disable and re-enable the keyless entry system, if yours is an early L494 it may be the same, just a thought. |
aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 50 ![]() ![]() ![]() |
Agree. Tried this about ten times on my 2012. It didn't work. As for "follow instructions to the letter", it is hardly difficult. Open door, sit in drivers seat, lamp button 3 times, and unlock button once. Not sure if it's a typo, but I tried this sequence with the "lock" button instead. Still nada. The suggestion that the key module might need a kick up the A is worth considering ![]() Alan Series 3 109 Classic 2-door 101FC GS Three P38 4.6L RRS mk1 2012 |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 100 ![]() ![]() ![]() |
Slight addition to the end of the process
Well, I was pretty much doing this anyway I think.
I must admit it took me an age to get the process right.
