Home > General > Water in Drivers footwell 2013 RRS black edition |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 206 |
Hi I think and I’m sure those more informed than myself will correct me the external window pillow trim can cause a leak problem I believe there are kits available to resolve this it may be a good place to start. n |
Mon May 03 2021 9:21pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4845 |
As suggested would be a good starting point, but I would think a 2013 car would have the "improved" style clips, however that doesn't mean to say the foam seals on them have not deteriorated over time, or if had screen replaced at some point could have been damaged in some way, if you do remove the trim buy new clips first as there is a strong possibility some will break when removing it.
Mon May 03 2021 10:52pm |
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 |
Tue May 04 2021 12:06am |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Depending on purchase date it may still be under warranty. |
Tue May 04 2021 6:37am |
