Home > Maintenance & Modifications > FBH leaking
gogsy1956
FBH leaking
Hi,, has anyone ever had to overhaul or repair a FBH?. I noticed on mine the other day that an amount of smoke was coming from the near side front wheel arch,,,, thats ok I thought as the temp was just about 5 deg. A little later the same again,, but outsidetemp was a lot warmer so shouldn't have been working. When I got home lifted the bonnet and plenty smoke around the heater,, let it cool a bit and found a diesel stain on the top of the wheel arch under the heater so it's obviously leaking but not sure where. Fuel pipe looks OK but without taking the unit out can't really see much, did manage to source a seal kit from the webasto Web site for about £15 but just wondering if anyone has had any dealings with problems on these units. Unplugged the unit and no leaks when the engine is running. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #612179 Thu Apr 01 2021 2:30pm
riverblanche
pop over to the D3 side of things as there is a FULL section on the FBH, with a couple of very good strip/rebuild threads.
be warned though there are lots of threads to read Laughing
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #612188 Thu Apr 01 2021 5:40pm
Oldandconfused
As riverblanche suggests, try this one;
https://www.disco3.co.uk/forum/robbies-gui...36766.html
Post #612191 Thu Apr 01 2021 6:39pm
gogsy1956
Cheers guys,, just working my way through the posts,, but apparently leaking units are few and very far between 2010 RRS, TDV8
22" overfinch
Post #612197 Thu Apr 01 2021 7:42pm
riverblanche
have you used the "Search" to try and narrow it down a bit Question
I tried Leaking FBH, still got a number of results and heres another of Robbies, he does excellent write ups Thumbs Up
https://www.disco3.co.uk/forum/fbh-fire-ri...eaking+fbh
Post #612207 Fri Apr 02 2021 12:50pm
gogsy1956
Just been having a quick look through the post and I did notice on mine that the rubber connection is anything but flexible,,, maybe this is the problem, I will have a closer look over the weekend hopefully.
Thanks again 2010 RRS, TDV8
22" overfinch
Post #612209 Fri Apr 02 2021 4:18pm
