Home > Faults & Fixes > Roller Parcel Shelf a little limp.
Fantom Sport
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
My 06 plates parcel shelf although still retracts gets a little lazy towards the end and gives up the trying with 6'' left. Can the spring mechanism be tightened in any way?
Post #611983 Sat Mar 27 2021 12:08pm
Fantom Sport
Ok, managed to fix myself, very simple, undo the torx screw on one side and pull the end cap off. Pull the opposite end cap out just enough to turn it, wind it around a few times and push it back in. Replace the original end cap, it takes a little wiggling. Replace screw and job done. They only doubt I have is that only one side has tension on spring but it appears to work.
Post #611991 Sat Mar 27 2021 1:51pm
Stevepd
Good job and thanks for the explanation, as these get on I’m sure we’ll go looking for info. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #612016 Sun Mar 28 2021 6:52am
stevef1964
Cheers for the info. Just done mine.
Post #614859 Thu Jun 17 2021 1:39pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Useful info thanks for that. When I read the title I thought it said your parcel shelf had gone into limp mode 🤪 Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #614871 Thu Jun 17 2021 5:54pm
