Home > Technical > Transmission Fault message.
Jontee
Scotland
2008 RRS l320 TDV8, Transmission fault message appeared yesterday, drives fine in auto, however
when you select Sport/manual position it does not work & still shows D on the dash.
A couple of times I have travelled about ten miles in Auto mode, stopped, turn engine off, then restarted
and Sport mode worked ok. Today have done the same, but not working. appreciate any tips/ solutions regarding
this.
Post #611599 Wed Mar 17 2021 12:13pm
keith63
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Have you had the Gearbox Oil changed at all ?
Post #611604 Wed Mar 17 2021 3:18pm
1richard1
Hi is it regularly used or once in a while? i had transmission faults and other various ones it was down to the battery being low.
Post #611608 Wed Mar 17 2021 4:52pm
Read the fault codes
Post #611612 Wed Mar 17 2021 5:04pm
Jontee
Scotland
Hi, thanks for reply's, Gearbox oil has been changed, used every day, about 600-700 miles per week, New Yuasa 100AH
battery fitted 5 months ago, rear stop/ taillight bulbs changed, have been told to change brake light switch as often
causes silly faults? Have ordered Genuine switch to try!
Post #611663 Fri Mar 19 2021 3:17pm
