![]() | Home > Maintenance & Modifications > Metallic click from front on drive |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 ![]() ![]() ![]() |
So far I have had new PRO Bush ARB’s fitted to front. Both top and bottom suspension bushes replaced. Rear lower wishbones and upper rear bushes all replaced - it failed its MOT on the mushes.
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Not seen it yet but trapped unicorn is good one to start looking for, nothing stupid like anything in glove box or fridge? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784 ![]() ![]() ![]() |
Don't CV joints make a tick tick noise if lock is applied?
I’ll have a look at these. Will there by any noticeable play if I try to move the engine about? Previously owned 1999 Disco 2 TD5 Disco 3 HSE TDV6 2007 Gone 2007 TDV8 RRS1 in Buckingham Blue. How do know if the knocking at the front has been sorted? You can hear the knocking at the rear better |
I’m favouring the CV joints, but the noise doesn’t happen all the time, and seems to happen even when not on full lock. I had thought about the shaft and the rubber part, so again will look at this. Previously owned 1999 Disco 2 TD5 Disco 3 HSE TDV6 2007 Gone 2007 TDV8 RRS1 in Buckingham Blue. How do know if the knocking at the front has been sorted? You can hear the knocking at the rear better |
Def not coming from inside the car, and the glove box and fridge are full of sweets, clothes and other such delights. Bloody unicorns ![]() Disco 3 HSE TDV6 2007 Gone 2007 TDV8 RRS1 in Buckingham Blue. How do know if the knocking at the front has been sorted? You can hear the knocking at the rear better |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
sounds like a driveshaft CV to me. Try a sharp turn while pushing the throttle. if you hear it clicking it's a CV RRS 3.0 SDV6 HSE Lux
Hodson91 Member Since: 09 Jan 2024 Location: Washington, Tyne and Wear Posts: 26 ![]() ![]() ![]() |
Did you ever get to the bottom of this. My 2010 3.0tdv6 seems to be doing the same.
Yes, sorry I had thought I had updated all my posts when I left the site. I no longer have the L320 |
Well thank you for taking the time to reply to me.
