![]() | Home > General > Holding Gear |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5059 ![]() ![]() ![]() |
It's warning up the gearbox oil |
Yep just warming everything up, perfectly normal. 2006 2.7 TDV6 HSE in Cairns Blue. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9074 ![]() ![]() ![]() |
3500rpm up a minor hill is a bit excessive. We have a hill out of the village here and mine holds 2k up that when cold. 2012 SDV6 - it's missing a couple of cylinders
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I've noticed that on first start up, when I drive through our village at 30mph/2000rpm on the accelerator it holds 4th? gear (maybe 3rd), but if I engage cruise control, it changes up to about 1500rpm. As has been said, it only does this until warm. I assumed it was normal mechanical sympathy. |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 316 ![]() ![]() ![]() |
I live at the bottom of a long gradual hill and get the same thing from cold, I can sometimes get it to change up by easing off the accelerator slightly. I’m not a fan of reving the engine too hard from cold. Steve
The slightly higher revs is a strategy built in to the system to help speed warm up and thus reduce emissions. Getting warmed up quickly also helps to reduce engine wear if it means oil gets warm sooner and so better at lubricating things.
