Home > Technical > HDC Fault/ steering
daxmatt
HDC Fault/ steering
Hi All
Car's been standing for a month or two,went to drive it the other day,HDC fault came up.Looking on the centre screen it says the front wheels are steering to the right,when i move the steering wheel to the left the image on the screen starts flickering to the left,but jumps back and forth from right to left.
This is pointing me to a steering position sensor.Does anyone know where the said sensor is,or is it an integral part of the steering rack.Oh, its an 06 supercharged.
Cheers all Matt,
If anyone wants turn up and make me a good offer i may take it. Mad
Post #610898 Tue Mar 02 2021 3:46pm
The steering angle sensor is in the steering column and is reached from the driver's footwell. Needs to be calibrated, I believe, when replaced. Might just need to be calibrated anyway.
Alternatively, what's the battery like? Low battery will throw up weird and wonderful combinations of errors. 2012 SDV6 - it's missing a couple of cylinders
Post #610903 Tue Mar 02 2021 5:43pm
daxmatt
update
Ive found the steering sensor(inside by bulkhead).Upon closer inspection,the plastic thingy that slides over/round the steering shaft that guides/fits inside the steering sensor appears to be stripped,the sensor itself looks all good,i centered it and the hdc fault goes away.
The next problem is getting the steering wheel shaft out,looks like a right pig.The sensor was easy to get out.
Post #610904 Tue Mar 02 2021 5:47pm
daxmatt
Here's the fault :-
Post #611429 Sat Mar 13 2021 6:11pm
daxmatt
Hdc fault fixed
Now all back together,and steering controls don't work and air bag light is on,any ideas ?
Everything plugged back in,stalks work ok.
Its as if i've left a plug out,but its all back in
Post #611473 Sun Mar 14 2021 6:15pm
Flyfisherman
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Was the battery disconnected when everything was plugged back together?
Had something similar happen with a free lander 2. Forgot to disconnect the battery before unplugging and plugging connectors which then through up faults.
Post #611475 Sun Mar 14 2021 7:23pm
daxmatt
thanks for reply flyfisherman.
I just found the problem.
I took the clockspring apart,and the ribbon inside was snapped.It would of been my fault,when i disconnected the uj on the steering shaft ,i must of spun the steering wheel around,which in turn has snapped the ribbon inside the clockspring.(oups)
New one on order
Post #611476 Sun Mar 14 2021 7:29pm
Flyfisherman
That’s annoying but at least you’ve found the problem. 👍
Post #611480 Sun Mar 14 2021 8:52pm
