![]() | Home > Tips & Tricks > Main Battery Replacement |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
No you do not need to remove the wipers etc, its quite straight forward, although the battery is quite heavy and drops in at a bit of angle first, drop the suspension first makes it a little easier depending on how tall you are. |
Phileep Member Since: 04 Feb 2019 Location: LEIGH-ON-SEA Posts: 52 ![]() ![]() ![]() |
Thank you Col
Yeah, thats about it, the only things you will need to reset is the date on dash as will default to 2009 and the clock, will also need to reset window one touch operation, same with sunroof if you have one, thats about it, certainly don't need to pay anyone £75.00 to do it, that's half the price of a new battery.
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Changed mine 18 months ago in about 10 minutes. Very easy. Follow the top tip and drop the suspension. I also made sure the key was not in the vehicle and left a door open in case the electrics did play up and locked the vehicle.
Thank you Col and Silverstone.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
45 minutes and £75 to change the battery? Wow, talk about bending people over! |
Brilliant additional advice RRSTDV8. Would not have considered that so thank you. |
Photo in gallery.... |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
Changed mine last week I found a guide on here & followed it to the letter , took about 15 minutes the only difficulty is the weight as already stated. |
Black off first, then red. Red on first, then black. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 274 ![]() ![]() |
May be a daft question but what is the logic behind removing the terminals in that order?
The body, engine etc. are all "grounded" to the negative terminal. If you undo the positive first and, for example, allow your spanner to touch metal whilst undoing the positive terminal you create a circuit. By undoing the negative first, if your spanner touches anything on the body etc., it doesn't matter. When you then undo the positive, it doesn't matter because the negative is no longer connected to the body/engine so no circuit occurs.
Would you possibly attach a link to the guide you mentioned you used from this site please Boxers. I do not seem to find anything like it.
I have had a really good look on here & I am unable to find it, thinking back I may have just googled how to change the battery on a 2007 Range Rover Sport if no luck message me as I have it all written down. |
