Home > General (L494) > Keylees entry KVM module
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Hi I posted a problem 2 weeks ago. Basically I couldn’t gain entry in to the car with key fobs or keyless entry. I got into car with blade key then started it with key against the colomn . I then checked 2 fuses marked up keyless entry , put back in and all back to normal. This morning exactly the same happened, again when fuses put back in all ok again. I think it’s fuse 58 in the boot fuse board that make it work as I can hear a relay click when it’s put back in. Could the KVM module be on its way out? Has anyone had this replaced and how much did it cost?
Post #611117 Sun Mar 07 2021 7:35pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I had mine do the same in my l320 about £300 from indy if i remember right.
Post #611119 Sun Mar 07 2021 8:09pm
Johnrrs
Thanks for the info. I’ll monitor it for a bit longer to see if it happens again then get it looked at.👍
Post #611121 Sun Mar 07 2021 8:19pm
jases4x4
Now its working again, why not do the deactivation of the wireless signal trick it stops thieves from gaining the signal from your keys and been able to open your car with them rf extender devices they use. The keys still work for you just pressing the buttons, maybe then the keys will work fine if wireless signal is switched off from module.worth trying for a few days you can easily reactivate the wireless on the module if its the same problem then you might need to replace module.
Post #611125 Sun Mar 07 2021 8:56pm
Johnrrs
Yeah I may try that.
Post #611138 Sun Mar 07 2021 10:02pm
