Home > Faults & Fixes > Heavy Steering
mikey7985
Wales 2009 Range Rover Sport TDV8 HST Stornoway Grey
Heavy Steering
Hi all,
My TDV8 HST seems to have developed heavier steering than normal. Are there any checks I can make before I take it in to be looked at?
I’ve already checked the steering fluid level and it’s ok.
TIA
Mike 2009 3.6 TDV8 HST
Post #610298 Sat Feb 20 2021 5:00pm
knwatkins
It's likely to the be universal joint on the lower steering column. It's a common issue.
Make sure you buy a genuine one and not an aftermarket one. Aftermarket ones are known to be trouble straight out of the box more often than not. Kev
Post #610299 Sat Feb 20 2021 5:07pm
that's the cause if the symptom gets worse when hot.
If its heavyer below 30 mph, when cold it's possible its electrical, but more likely the joint above
Post #610302 Sat Feb 20 2021 6:10pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Mine started to act up a few weeks back on my MY 2012. It’s still under warranty, off to the stealer in the next weeks. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #610304 Sat Feb 20 2021 6:53pm
mikey7985
That’s great thanks guys I’ll get it booked in to LR.
👍😉👍😉 2009 3.6 TDV8 HST
Post #610308 Sat Feb 20 2021 7:28pm
Eaters
By "LR" do you mean a dealer? With a car that age I'd be inclined to see if there's a local independent LR specialist. I doubt using an indie will affect the car's value, and it's likely to save you £s and get you a better diagnosis. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #610338 Sun Feb 21 2021 10:21am
mikey7985
Hi there sorry for the slow reply...... there aren’t any local independents that I know of I thought it best to take it to LR. In all honesty it still hasn’t gone in and the steering has now developed a clunking when going around roundabouts and cornering. 😩 2009 3.6 TDV8 HST
Post #611074 Sat Mar 06 2021 8:30pm
Eaters
I'm sure some of the forum members will have local knowledge of a good indie near Bangor and will add their thoughts... Robin
Gone:
MGZTT 190 2.5
Post #611091 Sun Mar 07 2021 10:16am
