Home > Maintenance & Modifications > No more knocking from the front or the back BUT!
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Yes, after 4 years with my TDV8 the front and rear suspension no longer knocks. After a near silent 210 mile drive through the Highlands today, it drove better than the day it left the factory.
To get to this I replaced the front lower wishbones with genuine parts, after my Indie at the time noticed they were cheap pattern parts. Then I had the front ARB genuine LR bushes replaced with SuperPro Polly bushes, and then the rear lower arms replaced when the car failed its MOT last week on the bushes being shot.
Silence Whistle
Except the occasional ‘thump thump’ when I start to drive away, then once driving it disappears! It initially feels like the same as a flat spot on a slick tyre feels. Once cruising there is no noise. When I sop and pull away it starts again, BUT - Not always Big Cry
CV joint? Front diff?
Front hubs replaced 12 months ago.
Any ideas? Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #610649 Fri Feb 26 2021 8:47pm
Eaters
Hmm. Might need a bit more detail of the thump. But for starters, you say it disappears when cruising. Does it happen if you accelerate from the cruise? Or is it only when pulling away? Where is the thump apparently from? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #610684 Sat Feb 27 2021 9:27am
Oldandconfused
Rear prop shaft?
If you take off the heat shield that covers the rear prop you can inspect the rubber insert in the centre mounting, they do split with age. Give it a wriggle and feel for splits and if its completely detached from the carrier it will be obvious. The CV joints also wear and go stiff with time.
Post #610690 Sat Feb 27 2021 10:11am
MartinsTDV8
Only really noticeable when pulling off, whether its in a strfaight line or turning, so acceleration once moving seems ok.
I would say it feels like its from the FNS, but with these cars thats not to say it isn’t from the rear. Previously owned 1999 Disco 2 TD5
Post #610734 Sat Feb 27 2021 7:09pm
MartinsTDV8
Oldandconfused wrote:
Rear prop shaft?
I am doing a service on it this week, so will have a look at this. I had, as my post suggested, thought about the CV joint, but as its not ‘constant’ I feel its not them Rolling with laughter Previously owned 1999 Disco 2 TD5
Post #610735 Sat Feb 27 2021 7:10pm
Eskimo
I had similar thump from NSF.
Turned out to be the inner CV joint failed totally, was basically being held together by the CV boot Shocked Shocked Shocked
Had a new front drive shaft and the NSF wheel bearing done nice and quiet now Very Happy Very Happy 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #610750 Sat Feb 27 2021 10:23pm
MartinsTDV8
UPDATE - late again, sorry Bow down
So in the end it was a front CV joint - all grease lost and rusted solid, AND it was also the rear centre bearing in the propshaft. So I replaced both front drive shafts and the whole propshaft from parts from AF Motors. Thumbs Up Thumbs Up Previously owned 1999 Disco 2 TD5
Post #619426 Tue Nov 23 2021 9:57am
Stevepd
Excellent and thanks for the update. Maybe some day somebody may have the same symptoms. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #619438 Tue Nov 23 2021 2:29pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
It's so good when we get the problems and causes & remedies identified & posted. Thumbs Up Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #619443 Tue Nov 23 2021 6:10pm
