![]() | Home > Maintenance & Modifications > Just fitted 30mm rear spacers ๐ |
Does it not drive weird now? Thought spacers the same width should only be used front and rear to make the track the same as it would have been without spacers? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
That looks like it'll rub the wheel arch rim if the suspension gets compressed. 2012 SDV6 - it's missing a couple of cylinders
DwylieRRS Member Since: 01 Feb 2021 Location: Manchester Posts: 8 ![]() ![]() ![]() |
No a lot of cars will run dif sizes front to rear depending on look but no drives excactly the same Iโve been told but quite people that l494 should run rear 30mm and front either 20 or 25mm front max Also i think they look wider in the pics thereโs still plenty of space for it not to rub as standard the space is huge . |
