![]() | Home > General > Buying Help |
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480
3.0 diesel v6 HSE is probably the most common, lots of kit, hi/lo range 8spd on 2012 or 6 spd earlier, dynamic anti roll bars, etc. Autobiography even more loaded with kit.
| Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 354
Thank you so much for the info its a great help
| CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174
Here's my experience; I'm 6 years and 60K miles into ownership of my 2005 TDV6, and haven't had any thing more than what I would consider normal wear and tear.
Hopefully i will all cash at the time and will look here first as generally forum members do look after there rrs
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134
Hi and welcome,
| evets Member Since: 11 Jun 2020 Location: Manchester / Bolton Posts: 59
As members state there are various models engines and specs.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
If going for a 2010-11 car I personally would go for the TDV8, all the engine had their own possible issues the main one's being the TDV8 can suffer from turbo failure, TDV6 crankshaft/bearing problems and early 5.0L's worn timing chain tensioners. With the TDV8 you don't have timing belt to worry about so bonus, not sure if the TDV8 actualy has the cross over pipe which can fail on the TDV6 and be expensive repair I believe. The TDV8 can suffer from cracked inlet manifolds I think and can be also be expensive. The rest of the car all version seem to suffer same sort of issues with worn suspension bushes, door locks etc. so not probably much difference in choice there. The A/B would be the higher spec. car but it was only re-introduced as a sport in 2010 so might be few and far between in that year. I think the main thing is take your time looking for a well looked after example with a good history, I would prefer a higher mileage one rather than a low mileage one that's just been used to take the "little darling's to school". Apart from servicing and normal stuff like brake discs/pads, batteries, wiper blades etc. mine has had lower front arms, rear door latch, tailgate switch and one front camera and probably a few other odd bits just to keep it up together 7 years now on 72K. As said all personal choice but I think the key is take your time there are plenty of bad ones out there.
| Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 484
My 1st RRS was a 2012 and they have a few nice updates like rotary gear selector and electric tailgate, I think they fit these from 2012 but could be wrong. It was also the autobiography model which was very very nice. I have the newer shape RRS and there are certain things I miss from the older shape like 2 glove boxes, been able to fold rear seats flat as the bench seat lifted up where the new shape doesn’t . My2012 also had park heating with a separate fob which was great. My new shape par heating works on an app via phone and can sometimes take a few minutes to even link to the car where with the fob worked straight away . |
As COL states TDV8 suffers from turbo failure (sequential turbos) body off circa £2,000 Garrett turbos.
| ilard Member Since: 20 Aug 2010 Location: London Posts: 975
I don’t think we can say one drivetrain is better than the other reliability-wise. Especially at this age, because I think the maintenance/ love shown has a huge effect.
Thank so much guys i cant say enough how all the info you have provided has helped. I am prob going to try and change the car before July if possible
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
If it helps, here's a summary of the major things I've had done on my 2008 TDV8 having owned it for 5 years:
Lol
| All times are GMT |
