Home > Faults & Fixes > Suspension Issues. Valve Blocks and Compressor. |
WexMan Member Since: 15 Feb 2021 Location: Co. Wexford, Ireland. Posts: 14 |
Hi Folks,
Mon Feb 15 2021 6:34pm |
can you try clicking on the Gallery button and see if you can access the pdf there? Appreciate your help |
Mon Feb 15 2021 6:59pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
It opens in your gallery 2010 RRS, TDV8
Mon Feb 15 2021 7:05pm |
Do you know how I fix the link? Cheers |
Mon Feb 15 2021 7:08pm |
Hi Gogsy1956, managed to get it working. had to copy and paste the link rather than rely on the add photo button to create the link.
Mon Feb 15 2021 8:25pm |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 38 |
Awesome document. Thanx for the effort to share. Pete
Mon Feb 15 2021 11:07pm |
GT RRS Member Since: 02 Feb 2021 Location: Florida Posts: 35 |
Wow, Wexman - you are THE man!
Tue Feb 16 2021 3:41am |
I recommend changing the orings in the valve blocks rather than buying new valve blocks, just vet the orings from 4x4airseals.com. I recommend them as the orings they supplied me fitted perfectly unlike those i received from US supplier. I see you are based in US but i think its best to be confident the parts will work when the car is up on jack stands eh
Tue Feb 16 2021 8:30am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Wow - great write up Wexman. Sorry if this is mentioned in your paper and I missed it, but I occasionally had the Access Mode fault where it went to extended mode. My Indie suggested it may well be that the desiccant in the compressor had, leaked out into the pipework which gives the false reading that puts the car into extended mode. (Not sure if I've explained this properly). Anyway, he disconnected the pipes and cleaned them through (air hose I guess?) and since he did this it has been fine. I am sure that this is only a temporary fix and I will probably need a new compressor at some point. Just wanted to throw this into pot. Robin
Tue Feb 16 2021 8:54am |
I can imagine there are probably several other reasons for some of the symptoms i described, good to add the other possible solutions into the pot
Tue Feb 16 2021 9:07am |
Just an update. It just happens that my RRS went in for annual service and MoT today. I tried the Access Mode as I arrived at the garage and "Suspension Fault" appeared. I have asked my Indie to have a look but I'm guessing compressor. Will keep this thread posted with the outcome. Robin
Tue Feb 16 2021 10:03am |
Get the diagnostics on it. Could be height sensors. |
Tue Feb 16 2021 10:47am |
Coincidence that you have posted your findings and solutions wexman as I have just rebuilt my compressor ( Hitachi) as I started experiencing the odd suspension fault for no reason and as eaters did, faults when trying to go into access height. I bought a seal kit from landyair which included ew piston seal and Wear ring, dessicant, filters and o rings for the dryer plus a new end cap and relay,,, which wasn't needed but fitted anyway. Also got a delivery valve kit from 4x4 air seals. I was suprised how good mine was considering the age when I took it apart, the dessicant wasn't too bad but there was a slight amount of dust after the filters. There is a kit available for the exhaust valve, which I wish I had bought but I cleaned it as best I could while I had everything apart. I bought new seals for the valve blocks ( landyair) and so far have done he middle block as it's next to the compressor. Been testing it a little the last few days and no leaks so far,, pumps to off road height quickly but most noticable is the speed it comes down to normal then access height,,,, without fault so I'm guessing the exhaust valve was well overdue a service. I did find white dust in the middle Valve block and hope to get to the other blocks very soon. 2010 RRS, TDV8
Tue Feb 16 2021 11:33am |
Hi Gogsy1956. Agree, these units don’t seem to be in a terrible state when taken apart. Suspect they could be worse in humid climates where the dryer gets worked hard.
Tue Feb 16 2021 11:43am |
