Home > Maintenance & Modifications > Thermal jacket for main car battery
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Stevepd wrote:
Didn’t Kev (knWatkins) have one for sale from his L320?
Ive looked through his posts and cant see this one. Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #609913 Fri Feb 12 2021 6:20pm
gogsy1956
Disco Mikey is breaking a TDV8,,,, maybe he has one available,, visit a good indie to have it activated,, cheaper than buying an iid tool 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #609918 Fri Feb 12 2021 6:49pm
ilard
I’m with the ‘bad battery’ camp. -13 is not an issue. Ok, I get plugs could be a factor, but if you need external juice you can be sure that battery is not happy. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #609922 Sat Feb 13 2021 1:23am
riverblanche
regarding the FBH being locked out, it may be a cheap fix Question
depends what wires you have in the FBH plug, you can connect to a laptop with a simple home made lead or have a look in "The Shop" on here for a lead or it could be a fuse removal to reset it, you will have to search here or on D3 for the details
here you go
https://www.disco3.co.uk/wiki/Fuel_Burning_Heater Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #609946 Sat Feb 13 2021 6:09pm
MartinsTDV8
UPDATE
Yes I know it’s been a while, but with warm weather comes easy starting, so it slipped my mind.
Anyway, I charged the battery and it didn’t really help, so, I bit the bullet and bought the IID BT tool and FBH remote from BAS. Installed a new SIM card, sent a wee text, after unlocking and purging the FBH, and hey presto it worked.
I have been using it now for a few weeks as the temperature starts to dip and all is good;- well almost.
It looks like I might have some sort of battery drain as my battery registered 12.7 on the FBH text that I get, then it starts to drop to as low as 12.1 after 30 minutes? The battery shows 13.7 when the engine is running, and when taken off to charge, does get to a full charge pretty quickly (3-4) hours.
Could the FBH remote be the issue? Or is it likely to be elsewhere?
I’m concerned that the battery gets low, and the FBH uses even more volts so doesn’t start in any event! Previously owned 1999 Disco 2 TD5
Post #619242 Wed Nov 17 2021 4:56pm
