Home > General (L494) > Update L494 Climate controls from 2014 to 2016 Part No?
Page 1 of 3 123>
moonstone
Hi all,
I'm looking to replace the heater control panel on my 2014 RRS to the 2017 version that has the heated seat controls available on the left and right heater control dials.
NOTE - I'm not talking about the new touch screen interface. In 2017 they added the ability to control the heated seats without having to to do it through the infotainment interface.
I'd like to pick up the newer version on ebay but as they look exactly like the 2014 version I'm struggling to find the right one. Does anyone know the part number for the later version?
Thanks.
Post #609798 Wed Feb 10 2021 7:19pm
RRS4ED
I think this has been available 65 plate onward not 17. I am not sure whether they would be compatible but might worth that a try
Post #609810 Wed Feb 10 2021 9:47pm
moonstone
Looks like you're right. Any idea of the part number? 2017 was maybe when they brought in the better infotainment touchscreen?
Post #609816 Wed Feb 10 2021 10:35pm
Drago
You can try the link below, just need to select which one.
A few options available
https://parts.landroverenglewood.com/v-201...and-gauges
Just remember though that breakers yards will use the stamp number on the item
Which is different to the LR part number
Post #609817 Wed Feb 10 2021 10:43pm
RRS4ED
im also in the market so if you do find an answer please share. I was looking at some parts on ebay and it appears they are different but if you take yours off and have a look at connectors that might be one way of to find out.
I seen these two parts one of them doesnt say what year but the other one says 2015 but it appears they have different connectors. one has cable with a plug where other one has a slot
https://www.ebay.co.uk/itm/LAND-ROVER-RANG...Sw5SRfFsen
This one is 2015 one
https://www.ebay.co.uk/itm/2015-RANGE-ROVE...SwdMRbwdUg
Post #609818 Wed Feb 10 2021 11:02pm
SC247
GPLA18A802DH
Post #609835 Thu Feb 11 2021 8:32am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
I've done the very same in my 2014 Dynamic, you can use assembly DPLA-18A802-DH or GPLA-18A802-DH.
Definitely a worthwhile upgrade for the cost/convenience factor.
Mike
Post #609839 Thu Feb 11 2021 10:07am
moonstone
Perfect. Thanks guys. I've ordered one on ebay.
The main reason for wanting this is that I've installed an android head unit and it's a pain in the rear having to go back out to the original Interface to then get the heated seats working. This way, I can do it just using the Heater control panel on it's own.
Good to hear it's plug and play as I suspected.
Post #609842 Thu Feb 11 2021 12:14pm
2 RRS
Exactly the same reason I did it, it makes life so much easier with the Android unit fitted!
Post #609843 Thu Feb 11 2021 12:39pm
Dave-t
Mike
Are both of these numbers the updated version, one seems a lot cheaper than the other? Joined the X5 45e club
1994 Defender 90 300 tdi
Post #609929 Sat Feb 13 2021 11:23am
2 RRS
Yes, the DH suffix is the important part, I bought the GPLA version as it was available and the cheapest, works perfectly on my heated/cooled seats.
Post #609947 Sat Feb 13 2021 6:40pm
moonstone
All fitted. Plug and play as mentioned above.
Thanks for your help guys.
Post #610144 Wed Feb 17 2021 3:29pm
pjbracer1
I can confirm PN GPLA-18A802-DH is the correct PN and this is a pretty easy fit, just rear heater control surround (2 *mm bolts)
Just loosen enough to lay on floor
Remove the dash panel (its clipped on just pull the top first (left hand side)
The you can pull the hock stick silve trim up from the rear parts first and they clip off
Pop of the heater unit front cover again only clipped on
Then its 4 Torx screws
Pull forward then unplug
Adn then swap over and put back together, the switches only work when the ingine is running so dont panic!
Nice little upgrade if you can get hold of oen thats the only problem!
Just did a quick check and there is one here https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...SwLFJfjbj7
The silver part has a dent but it looks like it can be swapped for the one in your car arleady as it looks clipped in.
Handy for summer with the AC as you need to get them going asap! If a jobs worth doing, get a someone who knows what they are doing to do it!
RRS Autobiography Indus
RR P38 HSE V8
RRS Supercharged Santorini
AMG CLK Rear Tyre Shredder
Post #610725 Sat Feb 27 2021 6:06pm
moonstone
We're trading in the car now and so I'm now selling this item. Will update with a link in the For Sale Section shortly.
Post #627659 Tue Oct 25 2022 6:40pm
Karlp606
Didnt know you can do this!
Nice little upgrade!!
Would be interested in these if selling, my current dials are scratched so was looking at swapping them like for like anyway but these look a lot better Cool
Post #627686 Wed Oct 26 2022 11:16am
Page 1 of 3 123>
