Home > Technical > Selected gear state on 4x4 info screen not working??
Dunc101
Hi - ive a '57 TDV8, and ever since I bought it about 4 years ago, the selected gear notification on the 4x4 page of the centre OEM touchscreen always shows N, regardless of which gear im in.
Im guessing its supposed to change to P / D / R / etc depending on which gear is selected?
Everything else on the OEM touchscreen works fine.
Is there any reason the screen isn't seeing which gear im in?
Thanks,
Duncan.
Post #609673 Sun Feb 07 2021 10:24pm
Do you have tv ?
Maybe it’s to make it work while moving
Post #609676 Mon Feb 08 2021 8:00am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Re: Selected gear state on 4x4 info screen not working??
Thanks,
Duncan.
On my 2012 MY, it shows "D" in auto mode and the relevant gear selected ifvbeing driven manually.
Post #609736 Tue Feb 09 2021 3:00pm
Eaters
Hmm. On my 2008, I hadn't noticed this at all! Just been out to check and yes, it does show "P", "R", "N" and "D". It does not show the relevant gear when in manual however. Short video may follow. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #609792 Wed Feb 10 2021 4:36pm
Eaters
 Robin
Gone:
MGZTT 190 2.5
Post #609794 Wed Feb 10 2021 4:44pm
Dunc101
Interesting - thanks Eaters. Thats what mine is supposed to do then...just need to understand why its not doing it now.. Smile
Post #609915 Fri Feb 12 2021 5:40pm
Dunc101
Thanks,
Duncan.
Yes - that's what mine is supposed to do - albeit the earlier gen screen. Just need to understand why its not doing it now..
Post #609916 Fri Feb 12 2021 5:41pm
Dunc101
Andy K wrote:
Do you have tv ?
Hi Andy - I've got the TV input set up (aftermarket), but it did this before I fitted that, ive just never got around to looking to understand why it doesn't work. Have now decided to look to understand. At least looking at responses here I know my screen is not working as it should. Just need to understand why mine isn't 'seeing' the actual gear the car is in.
Post #609917 Fri Feb 12 2021 5:44pm
