| RRSPORT.CO.UK | ||
|  | Home > Technical > Heavy steering |
| Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321      | Don’t know much about the electric steering column as mine doesn’t have it but the steering on mine is really nicely weighted, never heavy even at low speed but she’s only on 19’s. Steve
|  Mon Feb 01 2021 10:20pm |
| lkdgndg1 Member Since: 15 Jan 2021 Posts: 32  | Mines on 275/40/20 ,would that make the steering a bit heavy at low speed ? | ||
|  Tue Feb 02 2021 10:51pm |
| Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321      | I would expect so, I’m sure someone who has 20’s will be along to confirm. Steve
|  Tue Feb 02 2021 11:32pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | There is a relay (small ecu) marked ZF to make the steering light at low speeds.
|  Wed Feb 03 2021 7:16am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Disconnect steering rack connector.
|  Wed Feb 03 2021 8:02am |
| Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100      | Can’t say I’ve ever noticed heavy steering at low speed, regardless of tyre/wheel size. I run 20s on mine in summer and 19s in winter. Now I think of it, the steering in my 2010 Sport is lighter than many other saloon/estate cars I’ve had.
|  Wed Feb 03 2021 8:31am |
| lkdgndg1 Member Since: 15 Jan 2021 Posts: 32  | Thanks for that Andy I’ll give it a go . | ||
|  Wed Feb 03 2021 8:28pm |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563      |
 My 2008 model is fine a slow speeds and I'm on the same size tyres as you. Steering feels good and I wouldn't have even thought about it but for your post. So it would suggest you have some sort of fault Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 | ||
|  Thu Feb 04 2021 2:55pm |
| Paulsinhis30s Member Since: 12 Jan 2018 Location: Wiltshire Posts: 20      | Mine is running the same tyre size as you, but the steering is not usually heavy.
|  Thu Feb 04 2021 3:26pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Oh yeah.
|  Thu Feb 04 2021 5:30pm |
| lkdgndg1 Member Since: 15 Jan 2021 Posts: 32  | Had the bottom plates off today near the steering rack and found the electrical connector right off not even connected so cleaned it up and refitted and now steering nice and light , what a difference .
|  Sat Feb 06 2021 6:00pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Nice easy one   | ||
|  Sat Feb 06 2021 6:29pm |
| lkdgndg1 Member Since: 15 Jan 2021 Posts: 32  | I’ve tried it in the auto and man position and nothing, not even a sound from the steering column motors . If I press any of the memory buttons on the drivers seat the seat works fine but nothing from the steering side , there was an item on the USA Range Rover site that does mention having the dealer disable the steering column feature but surely the manual adjustment should still work , I’ll get to the bottom of this one way . | ||
|  Sun Feb 07 2021 9:05pm |
| Posting Rules
