Home > Technical > How to recover failed RRS in P with EPB on!
muddywheels
Milk Float Man
Guy on disco raised an interesting question Shocked
If you could not start due to electrical failure how do you get it out of P and disable the handbrake Sad
Apparently on the disco you can manually release the handbrake as follows but not in the handbook and not sure if similar on RRS Bow down
buellbeast wrote:
Its a fairly easy task TBH remove the cup holder as you would to access the handbrake release to the front is a big red lever. Lift up the big red lever use a small coin to unlock and then lift and it whilst applying the brake as if the Handbrake is off the car will now free wheel.
Pictures below with central console remove but easily accessible with cup holder removed and the splash guard underneath it removed.
Pull the red cord first
Use a coin to turn the plastic safety lock then pull the red lever and gearbox will be released from park.
Then pull the Handbrake release just to the rear as usual if required. You now have a freewheeling Discovery you can push drag winch etc.
But what about the gearbox - would you have to put wheels under to move it Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #360217 Sat Oct 20 2012 10:02am
fkarim
Don't know about taking it out of P but you can manually release the parking brake at least on the pre 2010 models. This thread helped me in releasing the park brake on mine when I destroyed the brake shoes last month (thanks Bob).
http://www.rrsport.co.uk/forum/topic17273.html
Post #360226 Sat Oct 20 2012 1:34pm
flydive
Ok, you prompted me to investigate. I thought that there must be a way.
Here we go
This is for a pre 2010 RRS, LH drive.
EPB:
remove the 2 cup holders, remove the small round panel at the bottom,
inside you will see a "bicycle brake" wire with a loop, pull it to release the EPB(you might need a hook to make it easier)
Gearbox P position solenoid:
remove the small plastic panel in front of the parking brake lever,
look inside the hole towards the right(you need a flashlight) you should be able to barely make out a white plastic lever. Lift it using a screwdriver(Car key works too) while moving the gear lever
(should be the same on RHD)
P.S. Looking at the pictures, it might be the same on post 2010 '08 RRS TDV8
Post #360230 Sat Oct 20 2012 3:00pm
georgien
Belgium
I need same info for RRS MY 2017, please !! Nik
RRSport L494 SD4 MY'17
Audi Q5
BMW X3
Audi A6
Mercedes R
Volvo XC70
BMW 5
Range Rover Classic
UMM
Toyota BJ40
Post #609591 Fri Feb 05 2021 10:55pm
One way to release the EPB you can remove the park brake actuators from the calipers and wind the park brake off manually using torx drive bit.
Post #609592 Fri Feb 05 2021 11:18pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Well every days a learning day😀 I knew about the EPB release but didn’t know you could access it through the cup holder, didn’t know about the park release....do now.
That’s what’s so awesome about forums 😄👍 Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #609616 Sat Feb 06 2021 3:38pm
georgien
Belgium
Thanks Col but that was not my question.
"If you could not start due to electrical failure how do you get it out of P and disable the handbrake. "
Above explanation is about Disco and I am looking for identical solution but for RRS MY17.
Thanks for your help
Nik Nik
Audi Q5
BMW X3
Audi A6
Mercedes R
Volvo XC70
BMW 5
Range Rover Classic
UMM
Toyota BJ40
Post #609642 Sun Feb 07 2021 12:48am
Not sure about getting it out of Park, but according to the Workshop Manual that is how you release the L494 EBC if you have electrical failure, it is a totally different setup being electrical operation rather than mechanical as the L320/Disco which is as you say what the previous posts and pictures are referring to.
https://drive.google.com/file/d/1bc3AJsifo...sp=sharing
Found this bit about how to disengage "Park Lock" as well if it helps.
Post #609643 Sun Feb 07 2021 3:22am
georgien
Belgium
Thanks Col, exactly what I was looking for !
Nik Nik
Audi Q5
BMW X3
Audi A6
Mercedes R
Volvo XC70
BMW 5
Range Rover Classic
UMM
Toyota BJ40
Post #609652 Sun Feb 07 2021 2:40pm
Tyrefitter
I remember removing the cup holder on my15 & their is a red lever that you can pull,I’m guessing that’s how to take it out of park. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #609658 Sun Feb 07 2021 6:37pm
