Home > Maintenance & Modifications > Help! Body removed to replace exhaust pipe????
GunnerBill
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
2008 Ranger Rover Sport 2.7 TD
I've been noticing a hissing sound in time with engine rpm (getting louder) from left hand side of car, noise coming through the bulk head.
At first we thought it was a leaking boost hose. But on closer inspection it turns out to be the exhaust pipe going from the drivers side bank to the passenger side bank.
My mechanic is not a RR specialist (although extremely competent) thinks it may be body off or gearbox out to replace the pipe.
Any alternatives to this? Preferably cheap ones.... yes I know its a Ranger Rover!!!
Post #609512 Wed Feb 03 2021 3:34pm
DrRob
Ask Mike Park at MMP in Dundee Thumbs Up * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #609516 Wed Feb 03 2021 4:12pm
riverblanche
have a Search for "cross over pipe" there are a number of threads about it which should help you, just looked at a few to give a link but there are a few so worth you reading through them Question
seems Not to be body off but still a bit of a Censored
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #609521 Wed Feb 03 2021 7:38pm
Cross over pipe is a body off job. No doubt it can be done in situ, but at what point does labour doing it one way overtake labour doing it the other?
Benefit of body off is that it let's you do a number of jobs easily in one go.. 2012 SDV6 - it's missing a couple of cylinders
Post #609524 Wed Feb 03 2021 10:19pm
knwatkins
Body off or body on with the gearbox out. Kev
Post #609528 Wed Feb 03 2021 11:31pm
GunnerBill
Thanks for your replies.
Fortunately the car is completely covered in snow so I can forget about it for a few days.
It looks to me like a body off job, a local(ish) specialist agreed it could be done via the gearbox but on cars that age suggested there could be an issue with the bolts for that so body off would guarantee less problems.
Realistically coz lockdown I'm going to leave this until better times a) because the garage is miles away and how do I get back? b) I have no money and c) I don't need the car anyway!
Lol.
Post #609778 Wed Feb 10 2021 1:56pm
Eaters
This sounds like one of those situations where, even though you won't want to, the logic of doing everything else you can do whilst the body is off will pay off in the long run - assuming you plan to keep the car for a while. So it might be worth asking the question on here as to what the forum recommends you get your mechanic to do or at least look at. A 2008 RRS will presumably have done a fair few miles (I have just cracked 100,000), and that will have a bearing on what may be recommended. I know that, sooner or later I will need two new turbos and I'm trying to set aside funds to make sure I only have to have the body off once... Shocked Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #609790 Wed Feb 10 2021 5:03pm
My SDV6 had the cross over pipe replaced a couple of months ago. Body off but when it was off my indie replaced the fixed brake pipes that run along the chassis. Said it was a quick job with the body off. Now I know the fixed pipes are good for the life of the vehicle - except for accidental damage, of course. Did the ARB bushes too, I think (would need to check the receipt). 2012 SDV6 - it's missing a couple of cylinders
Post #609821 Wed Feb 10 2021 11:56pm
