Home > In Car Electronics > Radio on time with engine off |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 224 |
Sorry if this is a daft question but when cleaning the interior this week-end I turned on the radio and after a relatively short time it switched itself off with an energy saving message.
Mon Jan 25 2021 1:05pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
With keys out of the ignition I get about 5 minutes before the radio switches off (lock the car and it turns off immediately). Keys in the ignition it is about 15 minutes and with keys in the accessory position it stays on permanently. Times are guesstimates. 07MY RRS TDV6
Tue Jan 26 2021 12:43am |
Thanks for feedback guys. RRS HSE Dynamic SDV6 2014
Tue Jan 26 2021 11:16am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
I hook up a Ctek on supply mode via the towing electrics adaptor for exactly this function Visitor from fullfatrr.com
Tue Jan 26 2021 11:52am |
Tue Jan 26 2021 12:51pm |
My point was that of all the cars I've owned the RRS seems to have the shortest time for the radio to turn off without the engine running.
Wed Jan 27 2021 12:25pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
It's not that the radio and interior lights take power, it's that every ECU in the car is awake and active. Add them up and you're looking at a decent current draw. Maybe other brands use a different EUC strategy meaning lower current draw.
Wed Jan 27 2021 1:03pm |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
Are you sure your battery is good, I had the same thing as you (less than 15 minutes sat in the car, doors closed and nothing except the radio on) so I got my mechanic to use his fancy battery tester, turns out only 5/8 of the cells in the battery were good but you'd never have known it from starting / running etc.
Fri Jan 29 2021 6:30pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
"turns out only 5/8 of the cells in the battery were good"
Fri Jan 29 2021 8:59pm |
