Home > Maintenance & Modifications > 2008 RRS HST 3.6 TDV8 Overheating / using water
airc909
United Kingdom 2005 Range Rover Sport TDV6 SE Siberian Silver
hi,
my 2008 58 RRS HST 3.6 TDV8 (93k miles) is using water and the low coolant message is coming up on the dash
i have been stopping and topping up the water rather than letting it over heat
if you just left it though, it would over hear and eventually go into limp mode
before i have a specialist look at it, does anyone have any ideas to help me ascertain if the leak is internal or external?
hoping not head gasket but i bought the car with the fault so if it is the HG, i will either fix it or sell it as it is
the speed it uses the water seems dependent on how quick or slow you drive, if that helps
if i tootle around it can take 20 minutes for the coolant to drop
its a lovely example
Post #608888 Wed Jan 20 2021 7:43pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
I think the expansion bottles are known to crack and leak so I'd look there first.
Post #608891 Wed Jan 20 2021 8:40pm
airc909
hi quick update
i cannot see an obvious leak from the expansion tank.
also there is no heat from the blowers once running.
also worth mentioning that the coolant in the tank is froffing/bubbling very soon after starting the engine
thanks
chris
Post #609165 Mon Jan 25 2021 8:04pm
airc909
there is no oil in the expansion tank
and there is no sludge around the oil filler cap
can't see any white smoke from exhaust either
thanks
Post #609166 Mon Jan 25 2021 8:09pm
Headgaskets fail in different ways.
You have the compresssion into coolant failure mode by the sounds of it
Post #609170 Mon Jan 25 2021 9:04pm
Nilrem280
^ As Andy K says.
To confirm you could always run a 'sniff' test on your coolant and that will confirm the presence of exhaust gases.
Post #609178 Mon Jan 25 2021 9:50pm
airc909
Quick update
The car is at douglass motors in rugby
First off they did a chemical test to check head gasket but it came back negative (albeit they said it’s around 70% accurate)
Following that they checked both thermostats and both were faulty so they’ve replaced them Both and I think I recall them saying they flushed the system as well
Unfortunately the car is still getting a pressurised Coolant system pretty much immediately after you start it
As it stands they’re pretty baffled by the issue and have never seen it before
Currently waiting to hear back from them and then I can decide which way to go with it
Their communication has been great so far so I’m happy with it being there but not sure they’re going to be able to help me
Chris
Post #609450 Mon Feb 01 2021 11:28pm
geoffsnook
Does sound like the head gasket if the system pressurises quickly Thumbs Up
Post #609464 Tue Feb 02 2021 2:32pm
Justinthorpe
New Zealand 2008 Range Rover Sport TDV8 HSE Bonatti Grey
any updates on this? I have similar symtoms
I have a 2008 TDIV8 with similar symptoms, just curious if the problem was identified and fixed??
Post #628345 Sat Nov 19 2022 12:54am
