Home > Faults & Fixes > HELP A.S.A.P Car at workshop!
Niclas79
Sweden
So sick of problem!
My RRS TDV8 2010 started fine on thursday, was ok for 1000m and then the transmission failure Come up. Turned the car of and when I would start it again it woudnt start! The engine goes round but no start. Have brand new battery.
Today I tried again, engine starts like 1-2 sec then dies and wont start. Have full power on battery but still wont start for more than 1 sec.
So tired of all problems with RR.
If I have it in the warm garage this isnt happening.
And no one seems to know the problem.
Have searched all forums and seems like several have this problem...
Post #608827 Tue Jan 19 2021 12:32pm
amgmaj
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Try this mate it worked for many
&list=FL8KSabaMMBROCrh8h3zgzng&index=3
Post #608833 Tue Jan 19 2021 12:50pm
Niclas79
Sweden
Now the mechanic have called and they cant find any fault, no codes etc but the car starts when they have it in the warm garage. What Will I do?
Cant take the car outside because then I still have the same problem, wont start and gear box failure..
Post #608837 Tue Jan 19 2021 1:58pm
Sounds like a glow plug issue. One or more isn't working properly so the engine won't start when very cold. Either test/replace the glow plugs or fit a timer to the Fuel Burning Heater so that it runs for a while before you need to drive. Also results in warm air as soon as you get in. 2012 SDV6 - it's missing a couple of cylinders
Post #608851 Tue Jan 19 2021 5:17pm
Niclas79
Sweden
Called land rover and they tought it would be the main fuel pump under the Hood.
Tdv8 had that problem when its cold outside and thats why it wont start, it dosent get any diesel... wierd but sounds logic
Post #608861 Tue Jan 19 2021 11:56pm
I assume they have checked the glow plug fuses and relays, should be two of each, one for L/H bank and one for R/H bank in the engine bay fuse box.
Post #608862 Wed Jan 20 2021 12:43am
