![]() | Home > Maintenance & Modifications > Pre fuel heater |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
I think the ballpark figure is 5 deg for it to operate,,, also you need at least a quarter tank of fuel and a well charged battery. I don't think the engine temp makes a difference,, mine also operates when the engine is warm, it's outside air temp that will be the deciding factor. 2010 RRS, TDV8
This might help explain how it all works.
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 342 ![]() ![]() ![]() |
Thanks to you both gogsy1956 and col. I'll get my service guy to check it out. From your remarks it seems mine is working as it should, may need a clean up. Andrew Kennedy |
