Home > Technical > Smoke test leads to oil leak?
mgrover
Dunno if just sheer coincidence or what but when smoke testing the car there's a ton of oil dumped. So defo have a leak somewhere. But valve covers are all new.
The engine is also defo leaking oil. So anyone know what other gaskets might leak? Or a diagram of all the gaskets for this engine
Post #608094 Sun Jan 03 2021 10:51am
WHERE IS it leaking from ?
https://parts.jaguarlandroverclassic.com/p...and-rover/
Select Discovery 4.4
should be very similar
Post #608095 Sun Jan 03 2021 12:01pm
mgrover
honestly. i dont know. the car is in pieces yet again since injectors seals were leaking so i couldnt get under is and get properly. once i can fire it up i can get it back on ramp, then run another smoke test and lift ramp to see.
but since am ordering parts from LR anyways I thought if someone knew which gasket it was i only need to make 1 order.
Post #608112 Sun Jan 03 2021 4:32pm
