Home > Technical > Only half heated windshield works
Jackharrer
Poland 2010 Range Rover Sport TDV8 HSE Santorini Black
Hi Guys
Currently trying to fix problem with my heated windshield. Only driver side works...
List of what I checked:
1. Both fuses are OK
2. Voltage on both fuses is battery voltage - around 12,7 V
3. I disassembled both A pillar inside trims and checked voltage on cables which are connected to windshield . Driver side - around 11V and passenger side only around 5V.
Do you have any idea why there is only 5V on non working passenger side ?
Regards Oskar
Post #608060 Fri Jan 01 2021 1:02pm
sounds like you have a poor joint/connection between the fuse and windscreen.
I'd remove the fuse and refit to be sure it isn't a poor conection on one end.
Early models appear to have a ~4 pin connector with purple wires (by the A pillar)
Post #608062 Fri Jan 01 2021 1:28pm
Jackharrer
Dear Andy
You are right , fuse was very loose in socket, I "crushed" socket pins and now I have almost 14 V on windshield connector.
But still passenger half does not heat Sad Probably windshield has to be replace.
I just wonder why whole half does not work ? On driver side I have two or three "dead paths".
It is almost impossible that every path is broken on passenger side...
I have two connectors for each half, one black and one violet-gray each side which are connected to tape type wire.
Unfortunately this connectors are not decomposable...
Do you know what resistance should be between windshield connectors?
Post #608066 Fri Jan 01 2021 3:41pm
About 0.5R I think
Post #608068 Fri Jan 01 2021 4:29pm
