Home > Technical > Active control roll module
Page 2 of 3 <123>
Disco_Mikey
With a suitable diagnostic tool Thumbs Up
Post #607977 Tue Dec 29 2020 5:59pm
Simon_CSK
And that Mikey is the answer I was hoping to hear Thumbs Up Thumbs Up Thumbs Up Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #607984 Tue Dec 29 2020 10:37pm
Disco_Mikey
As long as you don't say Snap on, or Autel Wink
Post #607986 Wed Dec 30 2020 6:24am
Simon_CSK
OK got the part and have fitted it in a manner.
How in all goodness does the old one come out? The new one is in but obviously needs configured as there isn;t any change. Current cars
Range Rover CSK
Discovery 3 HSE
Post #608003 Wed Dec 30 2020 7:33pm
Disco_Mikey
If there is no change, that suggests that the original module isn't faulty Confused
Or was it from a non 3.6
Post #608008 Wed Dec 30 2020 8:58pm
Simon_CSK
Mikey
I don't know what the new one is from. I would suspect from a V6 next thing to do now is get it back on the computer and make sure it is configured properly. I am at the extent of my skills so it is garage bills from here unfortunately. Current cars
Range Rover CSK
Discovery 3 HSE
Post #608014 Wed Dec 30 2020 9:48pm
What led you to believe the original module was faulty and not possibly one of the two accelerometers being the suspect.?
Post #608015 Wed Dec 30 2020 9:57pm
Simon_CSK
Fault code came up on the computer and when I researched the meaning of the code there were 3 possible solutions. The first was the ACRM and the other two were wiring to the same. Easy to start with thecomponent. Current cars
Range Rover CSK
Discovery 3 HSE
Post #608016 Wed Dec 30 2020 11:00pm
Disco_Mikey
What codes did you have?
Post #608017 Thu Dec 31 2020 6:48am
Simon_CSK
U0434 Current cars
Range Rover CSK
Discovery 3 HSE
Post #608018 Thu Dec 31 2020 7:18am
Disco_Mikey
And codes from the other modules?
Comms codes are usually irrelevant in most cases...
Post #608019 Thu Dec 31 2020 7:31am
Do you have any warning lights or dash messages while driving ?
Post #608025 Thu Dec 31 2020 10:20am
Simon_CSK
Suspension Fault
Stop car
Stop engine.
from the message centre. Might not be the correct wording but it is the essence of the message. Comes up as soon as the car is started. Current cars
Range Rover CSK
Discovery 3 HSE
Post #608027 Thu Dec 31 2020 11:08am
Disco_Mikey
OK, but what fault codes?
Post #608029 Thu Dec 31 2020 1:14pm
idi
I currently have the same problem as you with the same message on the dashboard. I have replaced the ACR module with a brand new one from Land Rover and had it coded in etc and it didn't fix the issue.
Next step is changing the pressure control valve(s).
Post #608031 Thu Dec 31 2020 1:25pm
Page 2 of 3 <123>
