Home > Technical > V8 egr fault sensor A |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
I would hazard a guess and say he only way to cure it is to replace the valve especially if the engine has a few miles on it. Had this issue on mine a couple of years ago. It's not as much a problem on the V8 compared to the V6, but what I would say is,, if you decide to go down the replacement route,,, do both valves,, as you can bet your last dollar that if one has failed the other will follow close behind. I speak of experience g and doing both at once will actually save you a few quid. 2010 RRS, TDV8
Thu Dec 10 2020 9:06pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
Read the fault codes first.
Thu Dec 10 2020 9:58pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 225 |
Yes 2010 with 112000 on, fault code with my obd reader is P0405 egr sensor A low circuit. Car drives fine which is strange i would have thought the valve would be stuck open or shut so it would effect the drive, I usually go to Jas Landrover in York who are brilliant but fully booked until end of January so im looking for a garage abit closer to south yorkshire if anyone knows an Indy who really know what they’re doing. Not sure on cost either for both egr valves what did you pay gogsy if you dont mind me asking? |
Thu Dec 10 2020 10:58pm |
Wait for jas to do it |
Fri Dec 11 2020 1:05am |
Yes Andy I dont trust anyone else thats why i drive there and back twice for repairs just because of how professional they’re, unless someone can tell me theres another garage in yorkshire just as good. |
Fri Dec 11 2020 4:23pm |
