![]() | Home > Technical > RRS 2010 TDV8 Xenon leveling problem |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5104 ![]() ![]() ![]() |
Do you not have a label similar to this on top of headlamp unit?, should tell you which type of lamp you have.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5103 ![]() ![]() ![]() |
To the polish guy. These have air suspension so it doesn’t need vertical adjustment |
I think the AFS does adjust the h/lamp vertically based on speed of vehicle, don't know if it is the same motor used by the self levelling of the air suspension in some way though, although I think I could be getting the horizontal and vertical aspects of the AFS muddled up.
Jackharrer Member Since: 21 Nov 2020 Location: Sopot Posts: 4 ![]() ![]() ![]() |
Yes I have a similar sticker ( Valeo AFS cornering EU SPEC ). I also have L322 and although it has an air suspension it also has xenon leveling as well as many other cars. Probably all RRRS with Valeo Headlamps do not have auto leveling because they don't even have motor inside the lamp. ![]() Maybe someone can confirm that? The easiest way is to check if light goes up and down on start up. Regards ![]() ![]() |
