![]() | Home > General > Throttle body problem |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
I think it's all electric. Also my fuel trims are constantly at 20%. So if the plate is open too much at idle then it'll be open too far at max throttle. Anyone know how to reset it? I have gap and the dealer software |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5093 ![]() ![]() ![]() |
Could be part of the issue.
The thing is it works fine in Park? Or does the throttle body not open fully then?
At idle the throttle will only open a little bit. Even if you rev it
I've ordered a 2nd hand throttle body for like 30quid. I'll see how it goes. But it's the only thing wrong. Am tempted to just get a brand new one. But car will be off for a few days to get its alloys redone |
Also does anyone know what the values for the throttle are meant to be at idle? |
About 3% when cold.
Yeah it's about 3% from what I remember. I think what happens is when I floor it it skips a gear due to damage and ends up opening too much.
small update it now also throws the p2101-29 code. and i can make it reproduce in park just by opening more throttle. am just waiting on a replacement TB and we'll see how it goes. I might just connect the new TB in terms of electronics and see if itll operate in key mode 2? |
I can see the problem.
am just hoping this fixes the issue. but now the car runs lean AF like 20% all the time, am hoping thats due to throttle body but the TB is past the MAF so not sure if the TB is taken into account when calculating trims. |
It’s much worse than before is it? In terms of %
its way worse than before, idle is just constant 20% short term and long term is around 22%. So am hoping its the TB issue. The first thing I did was smoke test, showed nothing at all. |
