![]() | Home > General > shes on her arse... |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
The fronts and rear axles are controlled by their own valve blocks so there isn't a common point of leakage between them.
| mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393
okays, currently the supercharger and manifold is off |
Going back up to extended height is a sign of a blocked compressor exhaust valve. Otherwise, a height sensor might be dying as you suggest. 2012 SDV6 - it's missing a couple of cylinders
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
The computer self levels when parked.
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Another fault cause when going into extended mode after selecting access mode are failed dampers that are no longer able to be compressed. This therefore simulates the vehicle being grounded on an object.
Mgr it may not require damper replacement.
since am a nutter who bought this car at 130k with no service history, is there a way to tell if the struts/bags have been replaced? |
Have a look at them. The manufacture dates are printed on the white label stuck to the aluminium shield.
oh definitely. if its the valve blocks ill be buzzing. but if the struts have been replaced recently then it would rule them out pretty quickly.
| All times are GMT |
