Home > Maintenance & Modifications > Replacement of Running Boards |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 83 |
I've got original Land Rover running boards on my Sport, which have been on the car from new and were on the original spec sheet.
Sun Nov 22 2020 9:33pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
I took a set off a previous sport, just bought a few 8mm x 25mm stainless steel setscrews, bit of copper slip, and just screwed them back in the threaded holes where the brackets were previously fitted, no problems.
Sun Nov 22 2020 10:49pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 750 |
This is how they are fitted, it will give you an idea of what's underneath (won't be as new and clean as this though, you may need to get the Hammerite out)
Mon Nov 23 2020 9:56am |
Thanks everyone. That's helpful.
Mon Nov 23 2020 10:20am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Hi Pete, you can buy a set of new, aftermarket steps for £99.99 with free delivery from TurboRevs... https://turborevs.org.uk/side-steps-runnin...sport.html
Mon Nov 23 2020 9:01pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
When I took the steps off my TDV8 I found the process to be straight forward. And they'd been off road too so probably more yuck forced around the fixings than most. I certainly don't remember it being a difficult job. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Nov 23 2020 10:04pm |
If they are genuine L/R boards you might find they are already stainless steel bolts fitted which should make it easier, I fitted a set of genuine L/R steps to my current sport and sure the kit came with stainless bolts.
Mon Nov 23 2020 11:10pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
As Kev has said,, turborevs are as good as you'll get for the money. Fitted a set a few months ago to mine as the old ones were rotten. I did coat mine with Hammerite but it didn't take too well to whatever paint is already on so I would try priming them first. 2010 RRS, TDV8
Wed Nov 25 2020 1:10pm |
That's brilliant thanks everyone.
Thu Nov 26 2020 10:19am |
The Turborevs boards look great
Thu Nov 26 2020 10:22am |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 313 |
I use mine but could manage without it but my wife is vertically challenged and requires hers to get in all though she never uses it to get out.
Thu Nov 26 2020 11:03am |
Hi Steve
Thu Nov 26 2020 11:28am |
Completely agree Pete, wouldn’t dream of trying to sell mine on if there was anything left of them when I’ve cut them off
Thu Nov 26 2020 1:39pm |
Thu Nov 26 2020 3:11pm |
