Home > Technical > EGR Delete
Ossie 1982
EGR Delete
I've seen a number of posts relating to EGR delete, remap and fitting a turbo drain. I'm in the process of buying a 3.6 TDV8 (2009 facelift with digital dish etc) so just wondering why these mods are done in terms of benefits i.e. Does it save the turbos?? Also what sort of costs would the mods incur? Any info appreciated.
Post #606981 Wed Nov 25 2020 10:40pm
Oldandconfused
EGR removal/deletion is very common on the 2.7 V6, not seen so much on the 3.0ltr.
From reading on here, it looks like it's not recommended for the 3.6 V8. Obviously not my personal experience as I've only had the two former; blanked them on my 2.7, no problems so far on my 3.0ltr ( Censored , done it now).
Post #606990 Thu Nov 26 2020 9:39am
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
I have the TDV8 , my indie advised against the EGR delete when I asked him about it so took his advice.
Post #606991 Thu Nov 26 2020 10:09am
DrRob
EGR blank and delete on the 3.6 TDV8 is a common mod.
You've posted the same question on the Full Fat forum I see Whistle * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #606994 Thu Nov 26 2020 10:40am
RRS TDV8 EGR delete isn't that common, I think. It requires a map change too so it's not a simple DIY job like on the 2.7TDV6.
Not sure there's much benefit to be had from doing it on the TDV8 as the EGR seems to be much less problematic than on the V6s. Certainly, in my experience they'll go 150k miles. 2012 SDV6 - it's missing a couple of cylinders
Post #607041 Fri Nov 27 2020 12:34pm
