![]() | Home > General > Front antiroll bar bushing change |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I had the front ARB bushes done on my MY10 with ARC bar this year. Someone on here reported it's a b*&ch of job and in fact the indi I use showed me a LR tool he had for the job. I had a quick look and decided to leave it to him. I cant tell you exactly how much he charged a I had a couple of other jobs done, and it didn't cost anywhere near £600. DON'T GO TO A MAIN DEALER! |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
Your title is “front anti roll bar bushing change” and you question is about front and rear bushes and drop links.
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
I did mine this year. The rears are a very straightforward job and even though access is a little tight, it didn't take too long.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321 ![]() ![]() ![]() |
One of the reasons I bought mine was how well it drove, it had had a load of money just spent on the suspension, wishbones,bushes, drop links then the dealer put a new pump, rear junction block and a suspension unit to cure a fault light.
Snow White Member Since: 09 Jan 2018 Location: Mid Norfolk Posts: 31 ![]() ![]() |
I had a serious attempt at changing mine.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
You can buy the special tools here, scroll down to items 5 & 6 not sure if you really need both or could get away with one as don't really look to much different just the depth of the throat. Might be the sort of thing to buy then sell on when job done to recoup some of cost, sure plenty of members on forum would be interested in buying and passing on each time.
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49 ![]() ![]() |
I replaced the front and rear sway bar bushes on my 2008 tdv8 with active roll bar. I didnt have any special tools but I do have a two post hoist. It was tight and slow ie a twelfth of a turn, remove spanner, turn over, another twelfth a turn etc. No undue force required. So it is possible but I could have been lucky and just had a spanner that fitted. Pete
Pete
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 270 ![]() ![]() |
As a general rule on anything mechanical outdoors, I use copperslip grease on all nuts and bolts, Even those that I'm unlikely to dismantle again, but you never know! RRS HSE Dynamic SDV6 2014
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 ![]() ![]() ![]() |
Buy the bush and drop link kits from Advanced Factors, then send the whole lot with the car to a trusted garage.. should be 2-300 quid labour. Avoid a main dealer.. |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
It’s going to an Indy 😉😁 thanks for all advice 🙏🙏 |
[quote="Col"]You can buy the special tools here, scroll down to items 5 & 6 not sure if you really need both or could get away with one as don't really look to much different just the depth of the throat. Might be the sort of thing to buy then sell on when job done to recoup some of cost, sure plenty of members on forum would be interested in buying and passing on each time.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
You do need both.
Guess that answers that question then. |
