![]() | Home > Technical > ACE leaking |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
i always like to use maltings offroad. they've also been decent to me. also get yourself a few of the ram seals incase you butcher them. i find the oring fine but the small white plastic ring always gets mauled. |
the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64 ![]() ![]() ![]() |
Ive had good experiences of Maltings as well.
Most of the parts arrived today, so on getting back from work while there was still a bit of light, I managed to get the old rear ACE pipes off (Thanks Disco_Mike, just needed to get the heat shield off to get to that clip 10mm bolt) and the new rear pipes in place.
New valve block pipe seals still not turned up from DLS. Ordered on 6th Nov and they sent me collets by mistake. Flagged Wed, chased on Thu, but nothing turned up by Saturday and no confirmation that anything has been sent, so looks like another week off the road. Not a big issue but I am getting impatient to drive the thing.
Good luck with the valve block and the pipes.
A quick further comment on the valve block and seals.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4509 ![]() ![]() ![]() |
A normal 1.8 turbo will only do around 200bhp We've had our own Freelander 1.8T featured in LROi a few years back Currently off the road for a restoration, uprated turbo and bigger injectors ![]() |
That’s interesting to know. I live the idea of it.
This is a long way from having anything on it |
I have all the parts now and finish work early tomorrow!!
Aimed to get the thing finished today, with a few photos.
Managed to find an O ring and clip to sort out the fuel leak. When did diesel designers change the name of the leak off pipes to 'spill rail'?
