![]() | Home > General > Which RRS to buy? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
I think lower mileage is a good idea on these. Under 100K
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134
The problem is that the 3.0 and 2.7 can suffer from snapped cranks or spun bearings. There is no known fix for these.
| Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225
I was in the same position just over a year ago , always fancied a RRS but undecided on which engine, after discussion & reading various articles went for the TDV8 found one with full history & low ownership and absolutely love it , found a great indie for servicing & advice, certainly avoid LR dealerships. |
| Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100
I went for a TDV8. On balance of risks and horror stories I figured the risk with turbos was a better bet than the much higher cost of a replacement engine in a V6, plus a bit more grunt and a better noise!
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Should you go for the 2.7 or the 3.0? Neither. The 3.6 is the one to go for if you want a diesel.
I did say AndyK Therefore the cost of replacing the turbos on a v8 once, is insignificant I would think ? Dunno the cost ? I had no idea a quick search threw this up, not researched it so Mine just blew both turbos a few weeks ago due to an oil seal letting go in O/S turbo and that ultimately led to the N/S one being starved of oxygen apparently. Had only driven 1/4 mile, coasted round a 1st exit off of a roundabout, went to accelerate and umm... nothing! Recovered, RAC tried to start it but just clicked (knackered starter sound). End result, 2 turbos, new starter.. had brake pipes done whilst body off and a service and a few odds and sods..... �4.5k. I am not try to pick on one engine version, you need to try them all and decide what suits You (dont want the tdv8 guys ganging up on me either although a 5.0SC is always tempting gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
turbo cost a little more than I thought, but still cheaper than an engine change.
Regardless of which model you go for, if it's a diesel I would recommend that you change the oil and filter more regularly than the LR stated intervals. I do mine no later than every 5,000 miles.
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
I would say £8k + labour on a 3.0 is way off at today's prices. A new 3.0 short engine from Land Rover is around £4750 + VAT that's based on returning the old engine. Part number LR038138. A rebuild on a 3.0 will cost between £3k and £6k all in. Having had both a TDV6 and a SDV8, (with the SDV8 being in my FFRR, not my RRS) I would opt for the V8 any day, based on the driving experience. The drive is effortless. The best thing to do is to drive both and then make your mind up. Specs on paper are good as a guide, but you cannot make up for trying them in the flesh. Whilst the TDV6 does have a known issue with conrod bearings spinning and cranks snapping, the likelihood can be said to be low when you take into consideration the thousands of cars on the road. I think TDV8 turbos are more likely to need replacing at around 100k than replacing the engine in a TDV6. My advice is get what you prefer and go into it with your eyes wide open so nothing comes as a surprise. As for the gearboxes, I have found the 6 speed and 8 speed very good. From a usability perspective, I much prefer the stick on the 6HP over the rotary dial on the 8HP. It's just more intuitive. One thing I don't like on the 8HP is that when coming down a hill and braking then transferring back to the accelerator, it appears that the gearbox tends to be in too high a gear. Apart from that minor point, it performs well. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
What Kev says. |
I have just been listening to a few podcast from Chris Harris and one think that stuck was his comment on previous cars "You look back and remember the cars you have had, some for good reasons and some bad, but you Never look back and remember the Money you saved for not buying one ! if you want one and can afford it, Buy it" gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
That is very true indeed! However, that has now caused me to look back and think about it |
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480
2 turbos on an sdv6 is around £4k, new turbos. Body off. I still have my bill from 3 yrs ago.....
| All times are GMT |
