Home > General (L494) > Door Dents
louischristie8
2005 Range Rover Sport Supercharged Java Black
Door Dents
If you look in certain light and at an angle you can see 2 lines that look creases on the front doors. I thought these were dents that had been repaired / knocked out previously but I took the car to my body shop that a friend of mine owns and he says he's seen it on many range rovers and there is a brace in the door and its the brace which marks / indents the door which makes it visible from the outside. I only had noticed on the passenger side door, but then he showed me the driver door is exactly the same.
Anyone else noticed this?
Post #606287 Thu Nov 05 2020 10:50pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Just got mine out of the garage after reading this (2007TDV8) checked the doors & no marks visible.
Post #606317 Fri Nov 06 2020 10:37am
MrM
My 2017 has some lines coming down vertically from the door handle area, if that’s what you are referring to? If it wasn’t present on both sides id be more inclined to think it was a dent. Weirdly my bodywork had other “patterns” on it that my OCD self would consider dents, but the nature of them makes me believe they were probably like that from manufacture.
Post #606382 Sat Nov 07 2020 9:34pm
Farmer Chalk
I had this on my last RRS...it was black in colour and thus showed every mark...I thought it looked like there had been a repair in the area of the door handle...
Post #606384 Sun Nov 08 2020 9:03am
louischristie8
Sounds exactly what I’m talking about. Can see it in certain lights and angles.
Post #606388 Sun Nov 08 2020 10:24am
MrM
I assume it must be the way the door sheets are pressed at the factory and or bracing in that area. Dents and dings are more pronounced and have a defined centre or point to them. Any creases generally aren’t as long and larger ones have visible paint damage in my experience.
Post #606401 Sun Nov 08 2020 3:46pm
