![]() | Home > Technical > Headlight fault u1a39-87 |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5136
It sounds like a new battery is required.
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9154
Never had that problem when just scanning codes. Try fully charging the battery and see if your errors go. Monitor the battery to see if it's holding / losing charge. Might be a dying battery, might be a tired alternator, might be short journeys. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
| Ljdiscovery Member Since: 30 Apr 2016 Location: La Jolla, california Posts: 42
It has a brand new battery. The alternator is only putting out 12.75. It starts at 13.25 when first started and drops to 12.75 within two or three minutes. Truck has 41000 miles. Headlights have been non moving and cross eyed since I got it st 15800 miles. Phil
Alternator looks suspicious on those figures. 2012 SDV6 - it's missing a couple of cylinders
reporting back We had two issues. 1. female plug in the engine compartment fuse box was faulty. As I recall, it was the alternator fuse, 5 amp. We installed a stand alone fuse and it sorted the problem, for a while. 2. problem came back big time. turns out it was a bad ground. Had a new ground installed at a different location and all is well. However I still have the headlight fault. Low beam lights are crossed. Help...... |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Have you swopped headlights over to see if the fault code moved? A similar issue on a disco 4 was an internal wiring fault on the headlight unit. 2019 5.0 SC SVA (Current)
crossed headlight issues continue. I removed the left headlight and was able to take a small flathead screwdriver and manually turn the wormgear to straighten the low beam. It looked great. I plugged it in and turned on the headlights. Dang low beam shifted over crossed again. The motors work, I am wondering if I have a bad wire somewhere between the afs module and the headlights. I am in the USA with a left hand drive model. It looks like the AFS module is on the left side fender side of the footwell, as opposed to the right side on the right hand drive models. Ideas? |
Have you tried swooping the lights over yet? 2019 5.0 SC SVA (Current)
