Home > Maintenance & Modifications > Fluid drips at the rear |
You won’t notice any level change with a few drips. It’s likely just started leaking as you would have noticed earlier. I can’t see your photos but I would suspect your ARB or the pipes. 2012 5.0 SC AB
Sun Nov 01 2020 8:18pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Rear ARB. Budget £1500 to replace unless you're lucky and it's just the pipe union. 2012 SDV6 - it's missing a couple of cylinders
Sun Nov 01 2020 8:36pm |
Gjlatz Member Since: 01 Mar 2019 Location: UK Posts: 40 |
Thanks for the reply. Just edited the post and added the photos. I was initially glad it wasn’t the diff but I think the diff would be an easier fix.
Sun Nov 01 2020 8:38pm |
Hi RRSTDV8, thanks for the estimate. Do you know if the unions are accessible without lifting the body? |
Sun Nov 01 2020 9:06pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Rear body needs lifted to replace the rear pipes and/or bar... |
Sun Nov 01 2020 10:46pm |
Hi Mike, thanks for confirming. |
Sun Nov 01 2020 11:15pm |
p38 Member Since: 04 Jul 2019 Location: flintshire Posts: 49 |
Hi ive just had both of mine , rear and front, replaced and pipes replaced at wait for it £3500 i know its a lot of money but they had to be done. |
Thu Dec 24 2020 4:06pm |
Hi P38, thank you for the information. I have had a fixed price that is quite a lot less but I don’t know if we would be comparing like for like.
Thu Dec 24 2020 6:13pm |
