![]() | Home > General > 2006 Petrol V8 4.4 (maybe 4.2) |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5041 ![]() ![]() ![]() |
If you get 20 mpg I think that would be very lucky.
20'S is possible if you drive like miss daisey i used to get mid 17's more often than not and single figures when you hoof it which is so easy to do as the noise is so intoxicating lol |
r4_rick Member Since: 18 Aug 2013 Location: Northampton Posts: 15 ![]() |
Car we drove today did sound sweet!
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5070 ![]() ![]() ![]() |
You can get this mpg from a 5.0L if you try hard enough. |
Command shift issue is likely to be electrical |
I think I personally would be cautious of buying a vehicle with any known transmission fault, a possible worst case scenario could be the Transmission Control Module which is part of the main control control valve in the actual gearbox which could set you back a couple of K, or could be simple as oil contamination or corrosion on the electrical harness multiplug terminals where it connects to the transmission sump. I would certainly be asking for the fault codes to be read first.
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
always the supercharged |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
I can't speak to the RRS as ours is an sdv6 but I regularly get over 20mpg on my d3 v8 on a run without too much effort - thats an NA ajv8 4.4. I don't drive it hard to be fair but i'm well in with the traffic speed on a run and the D3 is much more of a brick than the RRS 2012 SDV6 HSE (technically its hers)
Paulsinhis30s Member Since: 12 Jan 2018 Location: Wiltshire Posts: 20 ![]() ![]() ![]() |
I have been running a 4.2 SC for just about 3 years, if i am really sensible on the motorway i can get 17mpg. But the car will tempt you not to be sensible, and you should go with it. It is without doubt my favourite vehicle after 30 years of car ownership, i probably should change it but i just don’t know what I would replace it with. Bite the bullet, go for the lower mileage option, get all of the suggested maintenance done and enjoy it. |
one thing i forgot to say about the 4.2, for christ sake avoid lpg at all costs. i know you might be tempted by like 56p a litre but honestly the cost of maintaining and fixing issues with it makes the whole endeavour pretty pointless imo. |
You say that but i had my lpg serviced on mine twice and was only About £50 each time but never had any issue's so maybe i was lucky and it was nice to use both petrol and gas and get over only just mind 400 miles without going to fuel station |
theres the whole valve seat issue. tbh i feel like i want too much from the lpg, ie i want lpg from 600rpm to redline haha while most swap to petrol at the top.
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Exactly the same!!! ![]() 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
Richturbo Member Since: 07 Dec 2014 Location: Cheltenham Posts: 9 ![]() ![]() ![]() |
Sold Range Rover Sport Autobiography Dynamic 5.0 Supercharged
