![]() | Home > General (L494) > Side Steps |
| Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436
It’ll be interesting to see how the brackets fair. I’m sure the6 are fine, just don’t look as substantial as the others Joined the X5 45e club
| Nano2nd Member Since: 23 Jul 2020 Location: Leicester Posts: 85
they were pretty weighty, in fact i was surprised at just how much the whole setup weighs! certainly not gonna help with fuel economy, hopefully they'll last, it was one of the more expensive options on the market.
| TigMik Member Since: 16 Jan 2021 Location: Manchester Posts: 5
So when fitting these Quicktread steps, are all the bolts accessible with no fouling from the undertrays or sills?
| Laurie100uk Member Since: 01 Nov 2020 Location: Bristol Posts: 41
I just bought one of the cheapest sets on eBay I think they were about £180 delivered. I don't have much car DIY knowledge but I managed to fit them in a day, they require some cutting away of the plastic covers that are restricting access to the bolts that are already drilled for them in the chassis. I didnt take any of cills off I just cut them away in situ with a jab saw, watching out for the fuel line hiding behind one of the ones at the rear. |
for the Side Steps ones you have to loosen some of the screws to the undertrays to get at the inner bolt holes, you don't need to cut them, you just need to lever them down a bit to allow access.. once the bolts for the brackets are in they trays just screw back into the original position, its a bit fiddly but not a major issue... be much easier on a proper ramp. 2020 Range Rover Sport P400e HSE Dynamic
forgot to say, just the fronts need the trays pulling down, the rear brackets you don't need to move anything, you can see the two holes in the pics above... the 3rd bolt clamps the big circles you can see in the floor pan. |
| m13lky Member Since: 08 Aug 2016 Location: Scotland Posts: 311
Nano,
yeah mines contract hire and that was my thought process too, plus i can just flog them at the end and get some of the money back yeah they are just standard tires and due to no spare you're taking a risk i suppose, i've never had to use gel on any car thankfully, but i've heard plenty of stories about it being pretty useless when you do need it! obviously with the battery pack theres no room for a spare, even a space saver 2020 Range Rover Sport P400e HSE Dynamic
| Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 262
Has anyone bought from Pegasus 4x4? They make a generic deployable version. https://www.pegasus4x4.com/land-rover/rang...ver-sport/ 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Those undertray covers on your newer model Nano are different to the ones on the older shape.The 13-18 L494 haven't got those cut outs for the step brackets. Andy.
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1921
As stated several times above the Sidesteps UK fit the 13 -18 models as well without cutting.
| Ratkat Member Since: 02 Oct 2017 Location: Wolverhampton Posts: 57
Ditto, as per my previous post I also had them installed on my previous MY16 AB Dynamic as well as my current MY19 AB Dynamic with absolutely no cutting, bending or forcing required on either vehicle. A 15 min job each side max with a couple of spanners/sockets only. MY19 RRS Autobiography Dynamic 3.0 sdv6, Carpathian Grey, black pan roof, black pack, black 22’s, black side steps, ebony/ebony interior
What weight are we talking for a set at £130, compared to a set at £400 because from what I’ve found so far, most are steel and heavy with only a few made of aluminium?? So which are the lightest set out there? |
| pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413
Ive had this done on my2014 and there were some parts of the under tray that required cutting to enable access to the mounting points. The mounting points are for the bolt and these needed to be tapped (I believe later models may have the threads pre cut and be plugged to save dirt ingress) The side steps butt up to the actual doors sill and the only thing that requires cutting is the tough plastic under tray which does have lines on them marking where to cut. I dont know about the 2018+ models but I cant think that LR would change that as part of the design but I might be wrong, I guess if its on lease then you could just go for it but if there was an issue you would have to remove them and then purchase new undertrays to put right I guess. If a jobs worth doing, get a someone who knows what they are doing to do it! RRS Autobiography Indus RR P38 HSE V8 RRS Supercharged Santorini AMG CLK Rear Tyre Shredder |
