![]() | Home > In Car Electronics > replacing gps antenna - are they year specific? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
Is it the taller aerial or the lower shaped one? as I think you may need to check your original Aerial to see if it has short fly leads on the aerial that connect to the main harness fakra connectors, the later aerials connected direct to the main harness so I don't think it would be a straight swap without changing the fakra connectors on the main harness from female to male or finding some short after market fly leads that are male/female. I had a 09 plate pre-face lift RRS1 which had the smaller aerial and it is the same aerial as my MY13 so would probably work but not totally sure.
trebor1677 Member Since: 03 Oct 2020 Location: kent Posts: 3 ![]() ![]() ![]() |
Thanks for your reply, I have had a look under the headlining there and it seems to have a couple of short leads coming from the shark fin fitting then has the connectors to the leads going presumably down to the dvd unit and radio etc.
You could probably use a couple of these to convert to newer style aerial, universal will fit all colour fakra connectors.
thanks Col I'l look into that option ! |
map_rrs Member Since: 30 Jan 2018 Location: London Posts: 32 ![]() ![]() ![]() |
Have been looking into adding a DAB aerial to the shark's fin on our 2006RRS and as a result I'm likely replace the Shark's Fin innards with the circuit board from an after market aerial that has DAB, FM & GPS on board - assuming it all fits of course
