![]() | Home > General (L494) > Oil leaks |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Arb piping not covered By LR extended warranty.
https://www.rrsport.co.uk/forum/topic54509.html 2022 P440e AB |
Drago Member Since: 23 Jun 2019 Location: Uk Posts: 64 ![]() ![]() |
Same old excuses from independent warranty companies then |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
Once again this looks like an advert for buying much more cheaply from a private seller and going for a warranty company that will actually cover the car, using the money saved from not going to a main dealer.
Can someone please confirm that the pipe below is part of the Arb piping?
Another picture for reference
.arb piping is made of aluminium Swiss cheese metal. That looks rubber?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5088 ![]() ![]() ![]() |
Could be one of the flexible hydraulic high pressure pipe's from the pump to the system, might help if you could get a picture of where the end of the pipe is connected. Google LR043711 or possibly LR056319 would depend on Vin No. which one I think, see if that brings up any pictures that look like it.
Thanks for posting the diagrams.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9084 ![]() ![]() ![]() |
Your first mistake was expecting a main dealer to be competent. Yes, they should be, but generally they aren't.
Just an update, had a call back from LR dealer. Both issues will be rectified under the approved used warranty.
