Home > Technical > Blown turbo
Tam boy
Northern Ireland 2007 Range Rover Sport TDV8 HSE Java Black
Blown turbo
Hi there
The turbos went on my range Rover Sport 3.6 I got them reconditioned and refitted but the smallest one seized right away again , only 80k miles on it and I’ve had it from new , any idea why ?? In
Post #605048 Tue Sep 29 2020 11:00pm
Disco_Mikey
Recons are not the best, I'll only fit a brand new OEM unit, as that's the only way the quality of the parts is guaranteed
Post #605050 Wed Sep 30 2020 4:41am
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Did you change the oil feed pipes, which cool the turbo, when you fitted the new ones? If you fail to let the turbos cool for a couple of minutes after a run the oil carbonises and blocks the pipes, which probably explains why the originals failed in the first place.
Post #605058 Wed Sep 30 2020 10:17am
Yeah I was going to say, you should change the oil feed pipe and return pipe.
Would be silly not to, you don't want a 3rd failure
Post #605064 Wed Sep 30 2020 12:01pm
Tam boy
All the pipes were throughly cleaned and checked, garage saying that some micro chamber in the block could of blocked causing it to starve the turbo of oil , ever heard of this ??
Post #605117 Thu Oct 01 2020 10:30pm
Tam boy
The saying now to replace engine think that’s a bit extreme tbh
Post #605118 Thu Oct 01 2020 10:33pm
Stevepd
Shocked find another garage. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #605123 Fri Oct 02 2020 10:18am
Oldandconfused
Surely the garage you used guarentee their work? That being the case it's down to them. Unless they advised changing items which you declined. Bet they change their minds about changing the engine.
Post #605125 Fri Oct 02 2020 10:57am
It's down to the garage to sort it out. They fitted the turbos that then failed. Their problem. I'd perhaps be inclined to suggest they fit new turbos and then you'd pay the difference between the new and reconditioned item price. That would be fair and you'd end up with decent turbos with a year's warranty. 2012 SDV6 - it's missing a couple of cylinders
Post #605127 Fri Oct 02 2020 11:09am
