Home > Technical > Help with stereo connections |
Joe Hankey Member Since: 16 Apr 2016 Location: warrington cheshire Posts: 104 |
Thu Sep 03 2020 1:27pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
Are you trying to fit an aftermarket stereo ?
Thu Sep 03 2020 8:55pm |
No. Just fit the one we have. As the aerial connection has been damaged. We need a new replacement connection and the one on has to be replaced with a straight one to length the aerial wire. I do hope that you understand this. |
Thu Sep 03 2020 10:17pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
Is it not just one of these you need. Have a look through this lot sure you will find what you are looking for.
Thu Sep 03 2020 10:34pm |
We need to make the wire long and then a new connection. Thankyou |
Fri Sep 04 2020 10:26am |
Thankyou very much. |
Fri Sep 04 2020 11:30am |
If you do buy the connectors and or extension leads make sure they are the Aqua Blue colour connector as in the picture, they are universal and will fit to any of the fakra connector colours as your connector on the back of the audio unit appears to be black. Unless they have changed the design black will only match black, green match green etc. You could actualy leave the outer coloured part off and use any one, unlikely they would vibrate off, but to me personally that is the typical half a job.
Fri Sep 04 2020 10:17pm |
Thankyou very much I will buy this one. |
Mon Sep 07 2020 12:24pm |
